纠结:高手给个建议!选择SPARTAN-3还是SPARTAN-3E?
3 replies [最后一篇]
FPGA菜鸟 的头像
Spatan3e系列最高工作频率达333MHz,可用来设计PCI接口;支持SPI配置模式;逻辑门数相对较少,2M以下,相对成本较低;Spatan3e有ODDR2组件,而spatan3不支持。
以下为网上资料摘抄:
* Spartan-3E family complements the Spartan-3 family – Spartan-3E optimized
for gate-centric designs with less than 2M gates, Spartan-3 optimized for I/Ocentric
designs from 1M to 5M gates
*Other Cost Saving Features: Spartan-3E devices include a built-in interface to
commonly used DDR333 memory. Also, the minimum DCM input frequency is
lowered to 5 MHz (Spartan-3 DCM min. input frequency is 24 MHz) enabling the
use of lower cost oscillators. Up to eight DCMs are available to eliminate discrete
DLL/PLL/phase shifter/clock management devices.
Choosing Between Spartan-3E and Spartan-3 Families
14. Does the Spartan-3E family replace the Spartan-3 family?
No, the Spartan-3E and Spartan-3 FPGA families are complementary: each is designed
to provide the best ratio of gates to I/Os for different applications. Spartan-3E FPGAs
are optimized for gate-centric (higher ratio of gates to I/Os) designs with under 2M
gates while Spartan-3 FPGAs are optimized for I/O-centric (higher ratio of I/Os to
gates) designs from 1M to 5M gates.
16. What are the feature differences between Spartan-3E and Spartan-3 families?
There are a few feature differences between the Spartan-3E and Spartan-3 families that
can determine which family to target for a new design. Spartan-3 devices in the
density range under 2 million gates (XC3S50 to XC3S1500) should be targeted if any of
the following “Spartan-3 only” features are needed:
• Digitally Controlled Impedance (DCI) also known as XCITE
• High current I/O standards over 16 mA
• I/O standards – GTL/GTL+/HSTL I/HSTL III/HSTL18 III/SSTL2
II/LDT/LVDS_ext
• Low-power option (Spartan-3L)
Spartan-3E devices should be targeted if any of the following “Spartan-3E only”
• Serial (SPI) or parallel flash memory used for configuration
• PCI 66 MHz compliance, PCI-X compatibility and mini-LVDS I/O standard
support
• DDR333 memory interface
• Fully pipelined embedded multiplier performance to 325 MHz
• Eight DCMs with 5 MHz minimum input frequency
Xilinx_boy 的头像
Spartan3-E器件在用户设计主要是Logic,对IO所支持的电平标准没有特殊要求的情况下成本相对会便宜一些,如果资源满足,Spartan3A系列的器件性价比也非常不错,其支持的电平标准要更多一些,而且是Xilinx主推的系列。
mingyi 的头像
是这样的,不必具结啦,楼主做项目还是学习
FPGA菜鸟 的头像
做个产品,监控用的
